DisplayPort Only Connects to Windows not Linux
I will test out the compilation with the lower link rate (HBR2).
When I try to dump out the MSA from the NIOS when plugged into Linux I sometimes run into a problem where the NIOS has become unresponsive. The DP Debug AUX trace stops printing mid line and does not respond to any commands.
I was able to print out this MSA dump:
------ TX Main stream attributes -----
--- Stream 0 ---
MSA lock : 0
VB-ID : 19 MISC0 : 20 MISC1 : 00
Mvid : 138E5 Nvid : 8000
Htotal : 0000 Vtotal : 0000
HSP : 0000 HSW : 0000
Hstart : 0000 Vstart : 0000
VSP : 0000 VSW : 0000
Hwidth : 0000 Vheight : 0000
CRC R : 0000 CRC G : 0000 CRC B : 0000
--- Stream 1 ---
MSA lock : 0
VB-ID : 00 MISC0 : 00 MISC1 : 00
Mvid : 0000 Nvid : 0000
-------- TX Link configuration -------
Lane count : 0
Link rate : 0 Mbps
------ RX Main stream attributes -----
--- Stream 0 ---
VB-ID lock : 0 MSA lock : 0
VB-ID : 19 MISC0 : 00 MISC1 : 00
Mvid : 0100 Nvid : 0000
--- Stream 1 ---
-------- RX Link configuration -------
CR Done: 0 SYM Done: 0
Lane count : 1
Link rate : 1620 Mbps
BER0 : 17F0 BER1 : 11A4
BER2 : 076C BER3 : 0DD8
HI dlim,
When I was trying out the different versions of Quartus (19.1, 19.2 and 20.2) I can see that 19.1 does not support the Bitec rev 11 FMC card but 19.2 does. However, the I2C setup commands for the retimer chip in the NIOS code is significantly different between 19.2 and 20.2. v20.2 also implements an MC_monitor and other new functions that v19.2 did not use. Which version of the I2C commands should I be using?
Daniel
- DZuck16 years ago
Hi dlim,
I am working on the v20.2 compile. In the meantime, I turned off AUX debug printout in software to ensure that I would be able to get my MSA dump printouts (UART otherwise can get stuck).
I am attaching two traces. One has multiple MSA dumps for Win7 and one has multiple MSA dumps for Win10. Both show that the LT seems to finish and then lose lock (CR and SYM transition to F and then back to 0). I have hooked up some of my LEDs to the the user_led_g[2:0] which are used to show dp_rx_vid_locked and dp_rx_link_rate. I am seeing that the dp_rx_vid_locked LED is always on and the dp_rx_link_rate LEDs are constantly toggling.
Would there be any benefit in testing an RX only design? Do you know where in the RX PHY I should be placing signalTap?
Daniel
- DZuck16 years ago
Hi dlim,
The v20.2 project compiled and I loaded it onto my board.
I am seeing that on the Win10 machine it never locks but it does lock on the Win7 machine. Unfortunately, I do not see any picture on the monitor I plug into the TX port on the bitec daughter card. I have attached the MSA dump traces for win7 and Win10.
Daniel
- DZuck16 years ago
I am not sure if it is relevant, but I had to unbond the TX lanes due to the layout of the FPGA board. The transceiver lanes are not in order going to the FMC connector and Quartus would not let me compile when they were bonded like in the sample design.
This change only affected the TX PHY IP core and not the RX PHY IP core.
