Direct RF Transceiver Intel FPGA IP in Stratix 10 AX
I am currently working with an FPGA Stratix 10 AX chip (1SA28T) and attempting to build a project using Quartus 22.3. However, I am encountering an error indicating that the drf_xcvr IP component is missing.
Upon further internet investigation and using QSYS, I found that this IP is referred to as "Direct RF Transceiver FPGA Intel IP."
I would appreciate any information regarding this IP, including whether it is available for download or how I can obtain access to it.
Any support on this matter would be greatly appreciated.
- Farabi_Altera
Regarding Direct RF related design, Altera will contact you personally. This is not available for commercial devices.
regards,
Farabi
- Bishnu
Hi Omar HS,
Which OS are you using to set up your Board? Do you manage to use Linux, or are you still on Windows?? The Altera/Intel board seems more reliant on the Windows OS.
