Digit Reverse Order issue for INTEL FFT IP core
Hi Chee pin,
thanks for your effort.
I am not quite understand it.
Can you suggest how can I turn the digit reversed result back into natural order output using my 8 bits index? because I plan to turn result into natural order result in FPGA and forward it to next stream for further usage.
my current logic is
assign digi_reverse_index[fft_result_address_width-1:0] ={result_index[0], result_index[1], result_index[2], result_index[3],
result_index[4], result_index[5], result_index[6], result_index[7]};
integer i;
always @(posedge clk or negedge reset_n)
begin
if(!reset_n)
begin
for (i = 0; i < data_num-1; i = i + 1) begin
fft_digireverse_result_r[i] <= 32'd0;
fft_digireverse_result_i[i] <= 32'd0;
end
end
else if(source_valid) begin
fft_digireverse_result_r[digi_reverse_index] <=source_real ;
fft_digireverse_result_i[digi_reverse_index] <=source_imag ;
end
end
thanks
Jim
I put form here to summary up, I am not sure with the same data source how can I use digit reverse output to figure out the target frequency .
