Differences in the use of Random Number Generator IP Core between Straitx IV and Arria 10
Thanks for sharing the msim_setup.tcl. I notice that you have commented all the libraries compilation related lines in the msim_setup.tcl. Sorry for any confiusion, please try to comment out only the following lines as in one of my previous notes:
1. Change "QUARTUS_INSTALL_DIR" to your local Quartus installation folder at line 114
2. Comment out "if ![ string match "*ModelSim ALTERA*" [ vsim -version ] ] {" at line 145 and its corresponding "}" at line 178
3. Commen out "if ![ string match "*ModelSim ALTERA*" [ vsim -version ] ] {" at line 186 and its corresponding "}" at line 215
Only 5 lines 114, 145, 178, 186 and 215 are to be commented out.
- Jessica6 years ago
Thanks for your reply. The simulation has been successfully implemented. But I noticed that the clock is 100MHz. I tried to increase the clock to 3200ps, there will be some other wrong with the results of simulation.
Thank you.
I want to simulate the quartus project containing random IP core. I followed the steps of "processing-start-start testbench template writer" but couldn't generate the testbench.
Then I saw a paragraph in msim_setup.tcl, as shown in the figure. But I'm not sure how to use "ip-setup-simulation --quartus-project = <quartus project>". When I type it in the tcl console in quartus, there will appear errors. When I input it in modelsim-altera, there also many errors.
Looking forward to your reply, thank you!
Continuing the previous reply, I added a figure about the errors of tcl console.
