Jessica
7 years agoDifferences in the use of Random Number Generator IP Core between Straitx IV and Arria 10
Simulate the Random Number Generator IP Core with ModelSim. The same testbench, when choosing different devices, the simulation results of rand_num_data are quite different. (1) When stratix iv (EP4...
CheepinC_altera
7 years agoHi,
Thanks for your update. For your information, I have sent you a simple SIV simulation design through email which I am using to test the SIV random number generator simulation in Q17.0Std. You may do the following to run the with Modelsim Intel FPGA Edition 10.5b:
1. Unzip the file
2. Open Modelsim and change directory to siv_randnum\siv_rand\simulation\mentor
3. Type "source msim_setup.tcl"
4. Type "ld" to compile
5. Type "do wave.do" to populate the waveform
5. Type "run -all" to start simulation
Chee Pin
Jessica
6 years agoHi,
Sorry, I have not responded recently. About your "siv_randnum.zip" file, there are many errors when I type "ld" to compile. See the attached txt file for details.
