Differences in the use of Random Number Generator IP Core between Straitx IV and Arria 10
Thanks for your update. For your information, I have sent you a simple SIV simulation design through email which I am using to test the SIV random number generator simulation in Q17.0Std. You may do the following to run the with Modelsim Intel FPGA Edition 10.5b:
1. Unzip the file
2. Open Modelsim and change directory to siv_randnum\siv_rand\simulation\mentor
3. Type "source msim_setup.tcl"
4. Type "ld" to compile
5. Type "do wave.do" to populate the waveform
5. Type "run -all" to start simulation
Chee Pin
- Jessica6 years ago
I follow the steps you gave. In the fourth step, the error is as follows: Error: (vcom-11) Could not find altera_mf.altera_mf_components.
Thank you.
Sorry, I have not responded recently. About your "siv_randnum.zip" file, there are many errors when I type "ld" to compile. See the attached txt file for details.
