Differences in the use of Random Number Generator IP Core between Straitx IV and Arria 10
As I understand it, you observe some issue with the SIV random number generator IP in Modelsim simulation where at 320MHz, there seems to be Z at the output. To facilitate further debugging, would you mind to share with me a simple test design and test bench which could replicate the observation? Please share with me the specific Quartus version that you are using as well.
Chee Pin
- Jessica7 years ago
Quartus Prime Standard 17.0 is used. There are two main problems in modelsim simulation of random number generator, when using EP4SGX230KF40I3.
(1) The output (rand_num_data) is not synchronized with inclk.
(2) When the clock frequency is increased to 320MHz, the output (rand_num_data) will have an indeterminate state Z.
But, when using qsim, there are no problems appear.
The attachment is the project files.
Thank you.
