Design Store: "Arria 10 Scalable 10G Ethernet MAC+Native PHY with IEEE1588v2 Design" is missing ?
- 6 years ago
The document links in both the 16.0.2 and 16.10 have been updated to the correct document location.
Hi Jet,
Now I understand your problem. I can open the design.par file successfully from my Quartus v16.1
Looks like there is some issue with your Quartus design template. Have you tried to follow the instruction to launch and install design template as per the guideline in below reference design link
- https://fpgacloud.intel.com/devstore/platform/16.0.2/Standard/arria-10-scalable-10g-ethernet-macnative-phy-with-ieee1588v2-design/
I am not sure whether you need internet connection for the proper installation or not but feel free to try it out.
Let me know if you have try out everything and still face design template installation issue then I will consult Intel software team to look into your issue.
dlim
- JET602006 years ago
Contributor
Thanks a lot @Deshi, after follow your suggestion to install design template, my Quartus 16.1 can create example project successfuly. I'm building it now.
BTY, another problem I found is : that document link of "Arria_10_Scalable_10G_Ethernet_MAC_NativePHY_IEEE1588v2_user_guide" points to an Irrelevant doc ( https://www.intel.com/content/dam/altera-www/global/en_US/uploads/5/52/BeMicroM10_Simple_PWM_Lab.pdf ). so where can I find the "Arria_10_Scalable_10G_Ethernet_MAC_NativePHY_IEEE1588v2_user_guide" ?
Thanks & Best Regards
- Edward_M_Intel6 years ago
