Gyud0
6 years agoDefault Parallel Flash Loader isn't working
Hey, I have a problem with Cyclone 3 device. The default Parallel Flash Loader (PFL) isn't working. I need a PFL for Active-Parallel configuration. I noticed that there is a PFL IP by Altera but ...
NurAiman_M_Intel
6 years agoHi,
Apologize for the misunderstanding.
PFL IP do support Active parallel but only applicable to Cyclone 3 and 4 only. Active parallel supported common flash interface(CFI) parallel flash memory. Hence you may refer to AN478 for further information.
Thank you.
Aiman
