LChen23
6 years agoDDR4 CAS Latency (CL)Setting ?
Hi, in Quartus , S10 external Memory, The Preset of DDR4-2666V CL20 Component 1CS 8Gb (1Gb x8) , It seems the CL is 20, But after I apply, it shows the CL is 23. So , Why?
NurAida_A_Intel
6 years agoHi @LChen23 ,
Thank you for joining this Intel Community.
Memory CAS latency setting= additive latency (AL) + the CAS latency (CL).
This parameter specifies the number of clock cycles between the read command and the availability of the first bit of output data at the memory device. The value is depends on the memory device selected; you need to refer to the memory datasheet for details.
Hope this helps.
Aida
LChen23
6 years agoI find it in Datasheet. When enable BID ,the CL may change to 22,or 23…
Best Regard
陈亮
18017280310
