SSilu
6 years agoDDR4 calibration failures on Terasic PCB
I encounter intermittent calibration failures on Terasic DE5A-NET when using Kingston KVR24S17S8_8 memory. Calibration always passes on default memory modules shipped with Terasic PCB MTA4ATF51264HZ-...
ybin
6 years agoThe basic device for sodimm is MT40A512M16, but there are 3 part number, G6/G3/G1 according to sodimm datasheet. You can get the correct datasheet(G6,G3, or G1) and check the parameter. If you still have concern about MEM timing tab parameter after you get the correct datasheet, please update it in attachment and let me know.
