14 years agoDCFIFO Megafunction simulation problem
Hi, I am attempting to use DCFIFO megafunction in my design, but i can't get it running!! The input data to be written to FIFO is (45 bit parallel) streaming video data clocked at 5MHz (...
ZLu001
7 years agoI met the same problem three years ago and used wrusew or wrempty to finish the design. I tried recently, the rdempty problem still there, any solution now?
another problem, I tried to use different clocks for reading and writing, it doesn't function properly. any help?
as for the altera_mf library, in which file I should add the" -L altera_mf" in?
Thanks a lot.
