14 years agoDCFIFO Megafunction simulation problem
Hi, I am attempting to use DCFIFO megafunction in my design, but i can't get it running!! The input data to be written to FIFO is (45 bit parallel) streaming video data clocked at 5MHz (...
14 years agook, i've included fifo_new.v and here comes the error:
# 3 compiles, 0 failed with no errors.
vsim work.tb_dc_fifo# vsim work.tb_dc_fifo # Loading work.tb_dc_fifo# Loading work.fifo_new# ** Error: (vsim-3033) E:/ihtesham/Tasks_And_Projects/FPGA/IPCores/fifo_error/fifo_new.v(74): Instantiation of 'dcfifo' failed. The design unit was not found.# Region: /tb_dc_fifo/fifo_new_inst# Searched libraries:# E:\ihtesham\Tasks_And_Projects\FPGA\IPCores\fifo_error\work# Loading work.read_control_logic# Error loading design
The design unit was not found!! i am using modelsim (A)SE, so all atera libraries should be pre-installed and compiled, but looking at the searched libraries, it doesn't seem to be searching all altera libraries... # Searched libraries:# E:\ihtesham\Tasks_And_Projects\FPGA\IPCores\fifo_error\work
how should i make it search altera_mf library??
