14 years agoDCFIFO Megafunction simulation problem
Hi, I am attempting to use DCFIFO megafunction in my design, but i can't get it running!! The input data to be written to FIFO is (45 bit parallel) streaming video data clocked at 5MHz (...
14 years agoThe big difference between the two clocks shouldn't be a problem.
Are you sure those signals are in high impedance state? I don't see how the model could produce this. If there were an initialization problem they would rather be in the U or X state, but not Z. Are you sure the FIFO is connected correctly in your testbench?
