AGofs
7 years agoCycloneV-Fractional N- PLL definitions.
Good afternoon, I want to produce an output clock (82.5 MHz ) from an incoming Clock (160 MHz) by using of Fractional N-PLL. I chose "Enable Physical output clock Parameters" option. Then, I've ...
Rahul_S_Intel1
7 years agoHi AGofs,
The above is a known problem and it is not fixed as of now, any ways I will provide you a work around from t the below KDB.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd01162013_301.html?wapkw=enable+physical+output+clock+parameters
Hope it helps
