SSmit7
6 years agoCyclone V PCIe Hard IP is not initialising/resetting
Hello. I am using a Cyclone V PCIe Hard IP on a 5CGXFC3B6U19I7. I have been struggling to get the PCIe to reliably come out of reset. The design passes timing and I believe that it is setup correctl...
Rahul_S_Intel1
6 years agoHi,
Is it possible to send the same project just want to check the reset is connected properly .
And also want to know , the design is working as expected in other temperature setting
- SSmit76 years ago
Hello Rahul I tried to send you a private message, but it failed owing to the large file size. How can I send you a message with the necessary information? Regards Stuart - SSmit76 years ago
Hi Rahul
I managed to send you a private message. Please check that for the information that you requested.
Stuart
