Cyclone V: Meeting timing with HMC and DDR3-800?
Just to make sure your device can support this, fill out the spec estimator and check the results:
Since you're using an SoC device, are you using the HPS hard controller, an FPGA hard controller, or a soft controller?
Are you running your user logic half-rate or quarter rate (if supported for your particular configuration)?
#iwork4intel
- jrrguzman7 years ago
Hi @sstrell
I've checked the link and in principle I should be able to run DDR3-800 (400MHz)
I've got the HPS running at DDR3-800 without a problem. However I also want to use the FPGA HMC and drive another DDR3-800 memory chip. However, after pluggin in the values from the manufacturer, the Read Capture hold analysis has a 7 ps violation.
In principle, the HMC for Cyclone V only allows full data rate on the user logic. I've included the current configuration (maybe you can spot what's the issue)
Cheers.
