11 years agoCyclone V hard memory controller clarification
Hi, I'm relatively new to this stuff but have spent a few weeks getting to the point of understanding how fast I can stream data into DDR3 sdram on a cyclone V reference design (bemicro-CV). ...
11 years agoHey Lance,
Did you try running a Modelsim simulation? I think you would learn a lot from simulation waveforms, since you can see when a burst on the Avalon-MM interfaces become a burst on the DDR interface. You could then write the testbench to generate sufficient Avalon-MM bursts to saturate the DDR3 interface. In the case of a MPFE, you could create multiple masters and hit the DDR with burst writes only, burst reads only, or combinations of burst write and reads. Cheers, Dave
