Cyclone IV GX transceiver kit not detected by linux host
As I understand it, you encounter some issue when trying to interface with CIV GX devkit using one of the design example. To ensure we are on the same page, just would like to check with you on the following:
1. Which specific devkit that you are using ie FPGA devkit or Transceiver Starter Kit?
2. Are you using any design example generated by Quartus? Mind share with me further on where we can locate the design example to see if there is any specific existing AN or user guide for it.
3. Mind further elaborate on the issue of pin assignments in the project does not line up with devkit that you mentioned n question #2?
4. Mind share with me on the specific Linux kernel that you are using? Is it come together with the design example?
Chee Pin
