JLee25
Contributor
7 years agoCyclone IV GX SDI Multi-instances Reference
Hi, I am working on Cyclone IV GX, for multi-instances on Triple Rate SDI. Now I found reference design on loop out, that's fine. But I need multi-instances on my project. Do you have any data ...
CheepinC_altera
7 years agoHi Johnson,
Thanks for your update. As I understand it, you are observing Fitter error when you try to use different refclks for the SDI RX instances. Just would like to check with you in your initial design which passed compilation, how many MPLL has been used? You may check with the Fitter report to see if both of the MPLLs have been utilized even when you are using single refclk for 2 RX and 1 TX?
Chee Pin
- JLee257 years ago
Contributor
Hi Chee Pin,
1 MPLL has been used in 2Rx and 1Tx, PLL_5.
Also the SDI Tx uses a GPLL, PLL_1.
There's only 1 PLL left in the design.
The clock pin was M11/ N11 for this.
I have another clock locates at M7/ N7.
But can't be used in fitter.
FYI!
BRs,
Johnson
