JLee25
Contributor
7 years agoCyclone IV GX SDI Multi-instances Reference
Hi, I am working on Cyclone IV GX, for multi-instances on Triple Rate SDI. Now I found reference design on loop out, that's fine. But I need multi-instances on my project. Do you have any data ...
CheepinC_altera
7 years agoHi Johnson,
As I understand it, you have some inquiries related to using Triple Rate SDI in CIV GX devices. Sorry as I am not very clear about your specific inquiry. Just wonder if you are referring to how to create multiple instance of TR SDI IP in your design? If yes, as I understand it, each instance of the TR SDI IP only support one channel. You will need duplicate/create multiple instances for every channel that you would required.
Chee Pin
- JLee257 years ago
Contributor
Hi Chee Pin,
Thanks for getting back.
My question is about multi-instance TR SDI, especially reconfiguration.
The project needs 2 instances and each can work independently, 2 sets TR SDI Rx/ Tx, both channels can operate at different rate.
Target device is "EP4CGX30CF23C7",
And I instantiate 2 SDI Rx and 1 SDI Tx all at Triple Rate.
If all the SDIs feed the same clock source, then full compilation is passed.
But once I add another clock as source for Rx, Quartus complaint about not able to fit into the device.
As I realized, this device has 2 MPLL on left block which could be used for transceiver.
Any idea about how I could overcome this problem?
Thank you!
Johnson
