JBayl
5 years agoCyclone 10GX PCIe Hard IP bring up
My custom PCIe board with Cyclone 10GX is not getting recognized by my PC (no unknown device getting displayed on Device Manager). I've programmed it with a basic FPGA code based on example pr...
- 5 years ago
From the signal tap, it can check the clk0 frequency, and it is based on the 100Mhz PCIe reference clock. It sounds like either the clk0 itself or the 100Mhz PCIe reference clock is not stable.
SengKok_L_Intel
5 years agoFrom the signal tap, it can check the clk0 frequency, and it is based on the 100Mhz PCIe reference clock. It sounds like either the clk0 itself or the 100Mhz PCIe reference clock is not stable.
- JBayl5 years ago
Thanks SK! Your responses helped a lot in narrowing down the issue.
