Cyclone 10GX PCIe Hard IP bring up
- 5 years ago
From the signal tap, it can check the clk0 frequency, and it is based on the 100Mhz PCIe reference clock. It sounds like either the clk0 itself or the 100Mhz PCIe reference clock is not stable.
Could you please add the following in the QSF file, and then recompile the design and capture the signal tap again?
set_global_assignment -name VERILOG_MACRO "ALTERA_XCVR_A10_DISABLE_RESET_CONNECTED_TO_CAL_BUSY=1
Regards -SK
- JBayl5 years ago
Attached pdf shows what i'm seeing on signal tap.
Added that line you suggested on qsf, recompiled, programmed the MT25QU256, then power cycle.
Run acquire on SignalTap. I used clk0 (27Mhz) free running clock as SignalTap clock source.
Rechecked pin connection guidelines and all looks OK. It all appears to be pointing to PLL not locking...
