Cyclone 10GX PCIe Hard IP bring up
- 5 years ago
From the signal tap, it can check the clk0 frequency, and it is based on the 100Mhz PCIe reference clock. It sounds like either the clk0 itself or the 100Mhz PCIe reference clock is not stable.
Can you attach a simplified PCIe design that can replicate the problem here? I would like to do a sanity check on your design. Thanks.
- JBayl5 years ago
Attached. Thanks!
- JBayl5 years ago
I've powered up 3 boards and all aren't getting recognized. Main issue I see is that the core_clk_out_clk output of the HIP isn't toggling. I tied it up to a counter to a test point and no activity. PERST is high, which is OK, deasserted state. Refclk is toggling OK.
I think that may be the reason why I can't see the ltssmstate and other debug signals not toggling. No clock. Any advice where I should look?
Power up sequence looks OK. All sources OK within 100ms.
Thanks!
- SengKok_L_Intel5 years ago
Could you please use the attached SOF file and capture the signal tap? I would like to see if I can spot anything.
