Cyclone 10 gx hardware setup
hello,
We are developing our project using Cylone 10 gx FPGA. Issue is arise on starting the BTS(board test system). From this window the BTS application is not further proceding.
Anything have to change in file directory or anything else.
- Farabi_Altera
Did you check if the JTAG connection is good? Can you program the device via JTAG before run the BTS?
regards,
Farabi
- mehta_expai
yes i can program device using JTAG...
Furthermore, i have tested all user leds and pushbuttons on development boad....
But BTS is not running till now...
- mehta_expai
hi,
can u suggest me a sfp module under sfp cage for CYCLONE 10 GX development board.
thanks
- Farabi_Altera
This is the SFP+ module that used at Cyclone 10 GX development board.
regards,
Farabi
- Farabi_Altera
regards,
Farabi
