JLee25
Contributor
5 years agoCyclone 10 Gx FPLL Settings
I am looking for Cyclone 10GX FPLL data about the values for loop filter resistance, charge pump current...
My main application is using Nios II to dynamically change the values but I am ...
JLee25
Contributor
5 years agoHi JonWay,
Thank you for the shared data.
What I am trying to know is how to find proper fPLL settings for,
" loop filter resistance, charge pump current..".
I am not able to fine the guidelines like "AN-728".
As my design needs to manually adjust the M values dynamically.
BRs,
Johnson
JonWay_altera
5 years agoHi,
The excel sheet has the info of the loop filter resistance and charge pump as well.
Just like IOPLL, these values are auto calculated.
I would suggest that you follow the Youtube how-to to generate the mif, and then compare what are the changes in the loop filter/charge pump.
