Cyclone 10 Gx FPLL Settings
You can find fpll register map in: https://www.altera.com/content/dam/altera-www/global/en_US/others/literature/hb/cyclone-10/c10-registermap-official.xlsx
References: fpll is mostly for transceiver usage. For core usage, there is a how-to video that you can refer.
Hi JonWay,
Thank you for the shared data.
What I am trying to know is how to find proper fPLL settings for,
" loop filter resistance, charge pump current..".
I am not able to fine the guidelines like "AN-728".
As my design needs to manually adjust the M values dynamically.
BRs,
Johnson
- JonWay_altera5 years ago
The excel sheet has the info of the loop filter resistance and charge pump as well.
Just like IOPLL, these values are auto calculated.I would suggest that you follow the Youtube how-to to generate the mif, and then compare what are the changes in the loop filter/charge pump.
