PJoer2
6 years agoCVP initialisation for ARRIA10
Hi, we would like to know a **SIMPLE** way to be sure that a newly created core image (after design changes) is still compatible to an older peripheral image residing on the FLASH connected to an AR...
PJoer2
6 years agoHi,
thanks for the prompt reply!!
Just want to be 100% sure about your answer (since this realy has an impact on our development flow):
So what you are saying is :
- Although, CvP update (creating core images with the revision/block based design flow) works for our tests onARRIA10, it is not officially supported and might not work with future Quartus versions?
- Although the simple "ansatz" (simply change the design without touching the IO ring) works, there is no check to guarantee that a core works with the old peripheral for sure?
Many thanks again and kind regards!
Philipp
