ss
6 years agoCVO simulation configuration
I have a simple system consisting of a TPG and CVO. When I use the NTSC preset the CVO simulates fine. I added a MM BFM and load the CVO configuration registers. The video output of the CVO never ...
CheepinC_altera
5 years agoHi,
Sorry for the delay. Please correct me if I am wrong, Sherman has helped to open an IPS case on this and I have been keeping Sherman posted on the progress through the IPS case. I believe Sherman have been keeping you posted as well that Engineering is currently debugging into this. To facilitate the tracking, I would suggest we use the IPS case to follow up.
Chee Pin
