ss
6 years agoCVO simulation configuration
I have a simple system consisting of a TPG and CVO. When I use the NTSC preset the CVO simulates fine. I added a MM BFM and load the CVO configuration registers. The video output of the CVO never ...
CheepinC_altera
5 years agoHi,
Thanks for your update. For your information, I am still pending for valid response from Factory. As a workaround to avoid further gating your progress, just wonder if you are able to use Quartus version earlier than Q19.1Pro which should be working fine. Please let me know if there is any concern. thank you.
ss
5 years agoHi CheePin,
I can't use earlier versions of Quartus because they are not compatible with the SDI module.
