ss
6 years agoCVO simulation configuration
I have a simple system consisting of a TPG and CVO. When I use the NTSC preset the CVO simulates fine. I added a MM BFM and load the CVO configuration registers. The video output of the CVO never ...
CheepinC_altera
5 years agoHi,
Just to keep you posted that I have filed a case to Engineering on the CVO no output in simulation with embedded sync mode and currently pending for their response.
Just to check with you if you have had a chance to try on hardware to see if there is any difference in observation?
Thank you very much.
- ss5 years ago
I don't have an evaluation card or other hardware to try it on. I am attempting to simulate the design in advance of the board being built.
