ss
6 years agoCVO simulation configuration
I have a simple system consisting of a TPG and CVO. When I use the NTSC preset the CVO simulates fine. I added a MM BFM and load the CVO configuration registers. The video output of the CVO never ...
CheepinC_altera
6 years agoHi,
Yes, you are right, the example is only available for hardware. There is no test bench by the factory. Sorry for the inconvenience.
As a workaround, would you mind to try out in hardware to see if it is working on hardware? You can start with this example design or simplify the design for testing purpose. With a working simple design on hardware, you may create your test bench and simulate it in Modelsim. This could help to narrow down any potential simulation only problem and at the same time serve as workaround to ungate your progress.
