ss
6 years agoCVO simulation configuration
I have a simple system consisting of a TPG and CVO. When I use the NTSC preset the CVO simulates fine. I added a MM BFM and load the CVO configuration registers. The video output of the CVO never ...
CheepinC_altera
6 years agoHi,
For your information, I am still pending for valid response from Factory. To avoid further gating your progress, just wonder if you are able to use Standard Edition as a workaround? Sorry for the inconvenience.
- ss6 years ago
I have not taken the time to try the standard edition. The Arria 10 requires the Pro edition. I await your solution.
