ss
6 years agoCVO simulation configuration
I have a simple system consisting of a TPG and CVO. When I use the NTSC preset the CVO simulates fine. I added a MM BFM and load the CVO configuration registers. The video output of the CVO never ...
ss
6 years agoHi,
I also ran the simulation with separate syncs. I observed that the data changed following the input data but I had no sync signals
CheepinC_altera
6 years agoHi,
Thanks for your help. For your information, I am currently consulting Factory on this and pending for their response. I will keep you posted on the progress by end of next week or as soon as there is any valid response. Please ping me if you do not hear back from me. For the time being, as a workaround to avoid gating your progress, probably you can look into using Quartus Standard Edition with A10 device.
Sorry for the inconvenience.
