CVO simulation configuration
Just to keep you posted on my debug finding. Per my investigation using Q19.4Pro with S10 device (available in my local installation), I found that the issue seems to be happening when we are selecting the embedded sync configuration in the CVO. As I tested with separate wires, the CVO simulation seems to be working fine. I notice that in the Q19.4Pro CVO, there is an additional signal of sdi_cvo_rden. As I tested driving this signal to 1'b1, the CVO has a constant output which seems not right.
Can you try with separate sync to see if it work to narrow down our suspect that it is related to embedded sync?
Thank you.
I also ran the simulation with separate syncs. I observed that the data changed following the input data but I had no sync signals
- CheepinC_altera6 years ago
Thanks for your help. For your information, I am currently consulting Factory on this and pending for their response. I will keep you posted on the progress by end of next week or as soon as there is any valid response. Please ping me if you do not hear back from me. For the time being, as a workaround to avoid gating your progress, probably you can look into using Quartus Standard Edition with A10 device.
Sorry for the inconvenience.
