CVO II and genlock
I have a video processor design built using the VIP suite and everything is working as expected using a free-running CVO clock. However, my attempts to genlock the CVO to an external pll do not seem to be working.
I'm using the CVO II module and I have enabled the "Accept Synchronization Outputs" parameter in the qsys GUI. The CVO clock is derived from an external PLL and the PLL also provides a top of frame (TOF) signal which I have attached to the CVO SOF input and the CVO SOF_LOCKED input has been tied high. I have written 0x0019 to the CVO control register (Go bit, Enable Sync Output, Enable Frame Lock). The CVO generates valid video but I do not see any attempt to align the output frame with the SOF input signal. The Status register reads 0x0005 - the frame locked bit never changes. What am I missing here? Michael2 Replies
If at all possible I would suggest trying to use the CVO I instead of CVO II. The original CVO has been used with genlock in a couple of working Altera reference designs, but this hasn't been demonstrated for the CVO II yet.
This is the official response from Altera as well (via SR). The CVI II and CVO II do not currently support Genlock in spite of what the VIP Suite User's Guide says. We have already discovered that embedded syncs don't work for the CVO II (and haven't for several releases of Quartus). The new VIP modules do not appear to be ready for the broadcast video customer.
Michael
