CBlow
6 years agoCreate programming file for PFL FPPx16 with 4 Quad SPI flash
I have a design that will use 4 Quad SPI flash for PFL and FPPx16. How is the programming file created? Is it similar to CFI? The Convert Programming Files window does not list SPI flash for paral...
NurAiman_M_Intel
6 years agoHi,
What is the total size of Quad SPI flash that you were using? You must select the density that is equivalent to the sum of the density of two CFI or NAND flash memory devices. For example, if you require two 512-Mb CFI flash memory devices, then select CFI_1 Gbit as configuration device and then select FPPX16 as configuration mode.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf -page32
Aiman
