Create programming file for PFL FPPx16 with 4 Quad SPI flash
Kindly refer to PFL Intel userguide on steps to design by using more than one flash.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf - page 34
Do inform me if you need further information.
Aiman
I reviewed the steps on page 34 and my question is in regards to step 5 which asks to Select the .pof generated for the flash memory device.
Can you please clarify how this .pof is generated?
In my design the FPGA is Arria 10 with FPPx16 configuration, the PFL IP is in a Max V or Max 10, and there are 4xQuad SPI attached to the Max.
I have a .sof for the FPGA design, then I need to create a .pof.
In the Convert Programming Files window, I select .pof and select a quad spi configuration device, but the configuration modes to choose are only AS and ASx4.
Does it matter that the configuration mode is actually FPPx16 with the configuration file split between 4xQuad SPI?
Will creating the .jam file with a .pof created in this manner work properly?
