JLee25
Contributor
6 years agoCreate a VIP Component
Hi, Because of my project requirement, some of the VIP components will not work. Therefore I would like to know how to build and create my own customized component for VIP suite. Please help! ...
Deshi_Intel
6 years agoHi Johnson,
Sorry, I took back my word.
Pls refer to VIP user guide doc chapter 2 - Avalon Streaming Video as compare to generic Avalon spec that I shared with you earlier.
- The reason is due to VIP IP suite customized the generic Avalon ST interface bus to add in special design requirement like control packet and video packet data transfer.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_vip.pdf
We don't have Avalon ST reference design. We do expect customer to study the spec and timing diagram and code the design themselves.
- I think the closest reference that you can refer to maybe is VIP suite - test pattern generator II. You can run sim on it to learn how the Avalon ST video transaction works.
Once you have finished developed your own Custom IP design, then you can refer to below doc (chapter 2.8) to learn how to add/build custom IP component in platform designer to integrate with other VIP suite.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-platform-designer.pdf
dlim
