VBart
5 years agoCORDIC IP on EP4SGX70DF29C2X using Altera 15.1
Hi, for some reason i cannot generate the CORDIC IP for target device EP4SGX70DF29C2X. I tried other speed grades and they work fine. Any reason for this? Thanks!
CheepinC_altera
5 years agoHi,
As I try with the ALTERA_CORDIC IP -> Performance -> Check Performance, it seems like the IP does not work with the SIV part with -2X. I am not sure about the specific restriction for this with -2X speed grade device. As a workaround, it is recommended for you to choose other part with speed grade than -2X to proceed with the ALTERA_CORDIC IP. Sorry for the inconvenience.
Thank you.
