PBHAN5
6 years agoConfusion with Altera Soft LVDS Parameters- PLL setting
Hi, I'm trying to use Altera Soft LVDS IP core in TX mode with internal PLL. I'm confused with the parameter Data Rate, under PLL setting. Is it the data rate of incoming parallel data to the LVDS o...
Rahul_S_Intel1
6 years agoHi ,
The data rate is specified for the IO pins ,
kindly find the data rate specification in data sheet from table no;36
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
