Aiswarya's avatar
Aiswarya
4 years ago
Configuration of FIFO IP depth using constant
I want to know whether it is possible to configure the depth and address width of a FIFO IP using a generic parameter during instantiation of the FIFO IP?
  • MathiasB's avatar
    MathiasB
    Can you be more specific? I do not see why it would not be possible.
    What IP do you use? Intel's? Custom?
    The only problem I can imagine is Platform Designer (Qsys) getting in your way... Are you using it? If not how are you instantiating the IP?
  • JohnT_Altera's avatar
    JohnT_Altera
    Are you using it with IP generator or Platform Designer?
  • Aiswarya's avatar
    Aiswarya
    I am generating a FIFO IP using IP catalog window in Quartus. There I can configure the depth and address width of the FIFO.
    But what I wanted is to generate a FIFO in such a way that the depth/ address width can be passed to the FIFO IP using a generic parameter while instantiating this FIFO IP component in a wrapper file.
