COMPLETION TIMEOUT CONFIGURATION IN P-TILE AVMM IP FOR PCIE
Kindly note that we are using Intel P-Tile AVMM IP for PCIe, not Intel P-Tile AVST IP for PCIe.
Kindly note the completion time out is been disabled in stratix 10 , irrespective of Avalon ST or MM
- rkv6 years ago
Could you please make it clear? Does 'disabled' means
1)CTO value can't be changed. If so what's the default CTO value?
2)Completion Timeout won't happen. So the P-Tile IP for PCIe will wait for the response indefinitely
- rkv6 years ago
we are stuck at this point, kindly reply
- Rahul_S_Intel16 years ago
>> I do not have a default value for the completion time out
No, Timeout will happen, the time out is implemented in HIP ( Hard Ip)
Only difference from other family of Intel FPGA devices is that , customer cannot change the Time out value ,. The Time out will happen by the default value in HIP.
