Seadog
6 years agocompile error in A10 PCIe hard IP
I am getting this error message when elaborating a PCIe hard IP core with Avalon MM interface (build as a Qsys block with Platform Designer) Error(13224): Verilog HDL or VHDL error at altpcieav_dma_...
SengKok_L_Intel
6 years agoHi,
Thank you for your reply. I did compile the example design that generates from the GUI, but unable to see the same error. I'm not aware of the error that you reported here. If possible, could you please attach the QAR file that can duplicate the problem, so that I can look into it further? Or you may use the example design as the starting point and see if you can still observe the same problem.
Regards -SK
