srinivasan
5 years agoclocked video input IP
I want to use clocked video input IP for capturing 12 bit camera sensor data(Monochrome data)....I dont know how to configure the IP..can anyone share the example design project file for IP?
1 Reply
- Deshi_Intel
HI,
CVI IP is a video input IP that receive incoming video input data. So, different video input data format may required different setting in CVI IP.
Therefore, I suggest you to checkout CVI user guide IP to learn about the setting explanation so that you know how to configure to match with your own project application
Anyway, below is CVI reference design that intercept with DisplayPort Tx IP. You can check it out if you just want to get a feel how to roughly use CVI IP
dlim
