SBure
7 years agoClocked Video Input II valid resolution bit never rises
My test chain is TPG II() -> CVO II -> wire loop outside qsys -> CVI II. Video resolution is 1080, interlaced, embedded sync. I apply preset SDI 1080i in CVO and CVI parameter editor, only change it ...
Deshi_Intel
7 years agoHi Sergey,
Do you get expected output from VCO ?
Do you face this issue at hardware or sim ? It will be easier to debug in sim if possible ?
Which Quartus version that you use ?
I can try look for working CVO to CVI sim design so that it's easily to compare and debug your issue.
dlim
