UTech
7 years agoClock source IP is not generating the frequency provided in "clock frequency" parameter of the IP.
I'm using "Clock Source" IP provided by Altera in the QSYS. I gave 250MHz in "clock frequency" parameter, but it is providing only 100MHz from its output Clock interface. I confirmed it using Signal ...
sstrell
7 years agoYou could build your own logic to do it, but the easiest way is to simply use a PLL.
#iwork4intel
