clock control intel FPGA IP
Thank you for reaching out Intel FPGA Community.
If you refer to the Clock Control Block (ALTCLKCTRL) IP Core User Guide, it has mention that when you are using the glitch free switchover feature, the clock you are switching from must be active. If it is not active, the switchover circuit will not be able to transition from the clock you originally selected. Refer link below for the user guide:
Aqid
Hi
Your answer relevant to opertinal work with the this :
But my question is about the ability to enable the option of " ensure glitch free clock switchover "
I dont have the option enable this option at all and I get message that this feature isn't supported by this Quartus (my ver is 22.3)
When will you intend to enable this option ? which version this option will suuport ?
Yishay
