10 years agoCIC strange behaviour. Quartus prime 16.0
Dear Sirs and Madams,
i try to test CIC ip core. My parameters are: Input Sampling rate 120MSPS System Clock 120MHz Decimation rate 120 Input Channels 16. Problem is core does not generate start of packet and end of packet signals(of course i have this signal i code). Also i see result on wrong channel. Can anybody say something about this?1 Reply
My advice is to run simulation first of all, rather than using hardware captures. With sim you can follow events from the start while with hardware if a fault occurs anytime it will propagate through and gets hard to debug. There is also possibility of timing errors or fifos/rams getting out of control.
