Gsus
7 years agoChanging waitrequestallowance on the EMIF's slave Avalon Interface
Hi, We need a waitrequest allowance of 1 for the slave Avalon interface on the EMIF IP. Changing this value in the Signals & Interfaces tab under the Component instantiation window for both the mast...
- 7 years ago
Since the EMIF is an IP, it may not allow you to change the waitrequest allowance. You can see it on the Signals & Interfaces tab because this is common for all Avalon interfaces, but the IP may be overriding it.
#iwork4intel
sstrell
7 years agoSince the EMIF is an IP, it may not allow you to change the waitrequest allowance. You can see it on the Signals & Interfaces tab because this is common for all Avalon interfaces, but the IP may be overriding it.
#iwork4intel
